2001 LS1 Long tube Headers O2 Errors
Old May 27, 2013 | 01:38 PM
ckong's Avatar
Default 2001 LS1 Long tube Headers O2 Errors
Just bought a 2001 Ls1 with long tube headers and it has a service engine light. I had it checked at autozone and it threw 11 errors saying all the o2 sensors were bad. Ive read some problems with long tube headers and i dont have a lot of knowledge with mechanics.
* P1153 Heated Oxygen Sensor - Bank 2 Sensor 1
insufficient switching
ECM has detected switch ratio of rich to lean and lean to rich was belo a determined number
Probable Cause;
-Failed HO2S21 heater circuit
-HO2S21 signal shorted ECM ground
-Improper oxygen supply to sensor
* P0141 Bank 1 Sensor 2
heater condition
the computer has recognized a failure in this circuit
Probable cause;
-Faulty HO2S12
-Poor connection at oxygen sensor
-Circuit fuse
* PO155 Bank 2 Sensor 1
heater condition
Probable cause;
-Oxygen sensor defective
-Circuit fuse
* PO161 Bank 2 Sensor 2
heater condition
Probable cause;
-Circuit fuse
** P1133 Heated Oxygen Sensor - Bank 1 Sensor 1
Probable Cause;
-Failed HO2S11 heater circuit
-HO2S-11 signal shorted ECM ground
I need to get this car legal whats my best route?
Old May 27, 2013 | 02:54 PM
02DroptopZ's Avatar
My car would throw those exact codes all the time before I had a mail order tune done after my headers. I would try that first. Also, do you still have rear O2 sensors? Most of the time with longtubes those sensors get deleted which also will cause a service engine light until you get a tune.
Old May 27, 2013 | 02:59 PM
ckong's Avatar
Not sure about the rears atm, what type of tuning did u have done
Old May 27, 2013 | 03:44 PM
02DroptopZ's Avatar
It's just a simple mail order PCM tune, just Google "Tuned by Frost". He's a sponsor here and the one who did mine.
Old May 27, 2013 | 03:58 PM
ckong's Avatar
im looking into getting it locally tuned at PBJ here in st louis
Old May 27, 2013 | 05:08 PM
decipha's Avatar
they can take care of it as well
Are you near STL stangs?
Old May 27, 2013 | 08:04 PM
ckong's Avatar
im hoping to just tune out the rear o2's and
get the fronts working
Old May 28, 2013 | 08:09 AM
flattusmaximus78's Avatar
A tune will take care of the rears, and set the fronts to no report if they are in fact working properly.
Old May 28, 2013 | 05:37 PM
ckong's Avatar
sounds good, will tuning out the rears allow me to remove cat converts?
Old May 30, 2013 | 06:40 PM
ckong's Avatar
bump*
