Ignition timing thoughts
Old Jun 3, 2013 | 11:29 AM
PowerAdder's Avatar
Default Ignition timing thoughts
Long time lurker here. I've finally got my project done. L59 stock 5.3, side mount M112 7 psi, 150 shot, Meth injection. I'm running SD. 3500 stall 4l60 in a 71 nova ss.
If i go by the 1 to 2 degrees of timing pull per psi/nos shot i'll have no timing left lol. i'm thinking like 16 degrees? my iats are going to be beer can cold could i run more?
Old Jun 3, 2013 | 07:45 PM
BLK02WS6's Avatar
That is probably a good starting point, but you will need to get it on the dyno and see what it wants to make max torque/power - I'm sure it'll end up a little higher than 16, but hard to say how much more with a combination like that...
You think a 4L60E is gonna hold up long behind that?
Old Jun 3, 2013 | 09:17 PM
PowerAdder's Avatar
Its a street car, so it may hold a while as long as i keep the slicks off it. But when it breaks ill drop a 4l80 in.
