Weird readings
Your timing looks normal for part-throttle conditions. Once you get on the gas your timing should drop to ~22-24 degrees. If your timing is remaining high (30+) then it is most likley your MAF not reporting the proper amount of air. This causes your car to reference the High Octane Timing table at a point lower than the intended WOT timing settings.
If your Lterms are positive and less than 10, then I wouldn't worry about it and everything sounds fine.
