TCC duty cycle
Old Jun 23, 2013 | 02:36 PM
nj02z's Avatar
Default TCC duty cycle
Is setting my TCC duty cycle to 100 max 50 min ok? Car is 2002 Z28 with a Yank 4000 SS.I am new to this and I am hoping I am on the right track.Any recommendations would be appreciated. Thanks
Old Jun 23, 2013 | 02:39 PM
The_Bishop's Avatar
Set it to 100 max, 95 min. You don't want any slip with an aftermarket converter.
Old Jun 23, 2013 | 04:37 PM
nj02z's Avatar
Will you physically feel a difference with these settings?
Old Jun 24, 2013 | 12:58 AM
T/A KID's Avatar
Yep it will lock up like a SOB
Old Jun 24, 2013 | 06:17 PM
James@ShorTuning's Avatar
Depends on the clutch setup in the convertor being used but I always setup the TCC tables with aftermarket convertors to not slip. By setting the TCC to 100% on Max and 95-99% on Min tables you will basically get an on or off setting on your convertor. Factory tunes are setup to slip to lockup so it doesn't jar you when lockup starts engaging. Like said you don't want slip with an aftermarket convertor just due to the smaller surface area and clutch materials being used.
Old Jun 25, 2013 | 12:18 AM
Blown06's Avatar
8 Second Truck Club
It's not unpleasant, just like adding another gear to the trans...
