Tune help dies in Drive only.
Old Jul 27, 2013 | 09:52 AM
juicy's Avatar
Default Tune help dies in Drive only.
Ok car runs and drives in reverse, but as soon as I shift to drive or any forward gear the engine cuts off as if I had done it with the key. Car has H/C/I, stall all that good stuff. I have HP tuners and have gotten it to run and idle, but just dies immediately upon shifting into drive. A little background on the car I had put car all together only to find out that the converter was junk, sent it off to have it rebuilt. Had trans rebuilt while it was out. Put car back together and drove 5 feet in reverse and trans broke. Had it fixed put car back together and am where I am now. Any ideas what could be the cause?
Old Jul 28, 2013 | 01:32 PM
gagliano7's Avatar
You probably need to fix your raf table(base running airflow table idle) for in drive. Post your tune so people can help.
