Coil Pack Problems
Old Jul 28, 2013 | 05:39 PM
GhostofKrypton's Avatar
Default Coil Pack Problems
I have a 2000 trans am, and I am having issues with the driver side coils working. They work randomly, an I can not chase down the problem. I have checked all grounds, and they are good. I have checked all fuses and they are good. I have checked that the pink wire in the white connector is getting 12v and it is good. harness from white connector to the coils all have good continuity. Spark plugs are brand new, spark plug wire were ohm tested and good.
was throwing a p0200 code and so the injectors where tested as well, and no issue there either. the only thing that i can think of is that the signal wire from the pcm to the coils is not working, but i do not know how to test them to see if they are working properly. I have been having this trouble for months and still puzzling me. Any help would be appreciated, and if you need anymore information to help diagnose this problem, just let me know.
