Info for E85 tuning?
The thing is I put my car on E85 and switched the Stoich AFR to 9.75 and then began to monitor AFR's (LM-1) and adjust timing while watching for knock snd such. My car dyno'd 30rwhp less than what it does on pump gas. Even after adjusting the PE I feel as if I need more info before moving forward. The car seemed to run well at a 12.5 AFR and 30* of timing. Just doesn't make the power I think it should. I could be taking the wrong approach as well. Insight welcome!
(Car made 433rwhp and seemed to peak at 6000rpm. Graph flat lined and carried to roughly 6800. Since this pull I added a KB BAP and NGK TR6's. Looking for some more info before I put it on the dyno again)
You do also realize that since the stoich value of e85 is 9.765, you should be in the 8's when in PE on a N/A engine....correct?
The problem is, you're running the car WAY lean in PE.
Also...keep a good eye on injector duty cycle, as you will be requiring 30% more fuel as well....it's likely that you'll run out of injector (and possibly fuel pump) depending on your fuel system.
I have Bosch "Green top" 42lbs INJ (79% Duty Cycle WOT), I do have a single 255lph Walbaro pump. (Now with a KB BAP)
8's sound exactly right now. In the "How to run your LS1 on E85" he states the max power rich/max power lean and I was trying to figure out where I would apply those vavlues. I did average them out and found I'd like to be around a 1.27 in PE on the EQ Ratio. (Have not input this into editor yet, had to many questions)
Where I was messing up was referring to the AFR of gasoline instead of E85 on my LM-1.
I probably will run out of injector, we'll see. I bet that's why my motor only wants 30* as of now, it's running lean as hell. She want's a lot more fuel!
Fear LS, sounds like your car has a crazy setup!
