surges just above idle
Old Aug 5, 2013 | 10:38 PM
flywheel's Avatar
Default surges just above idle
Had car back to tuner to raise the TC lockup and tinker with the idle...He lowered the idle now it will die with sudden stops and surges just above idle.. Is there something I need to look for or is it in his tune....
Rick
Old Aug 6, 2013 | 06:33 PM
flywheel's Avatar
Really.
Old Aug 7, 2013 | 07:32 AM
gagliano7's Avatar
Probably in the tune but you need to give more info if you want help and post your tune.
Old Aug 7, 2013 | 06:42 PM
flywheel's Avatar
OK, here goes.
66 chevelle, 6.0l lq4/4l60E, ls3 intake, nw 92mm dbc,,.610lift cam,3200 revmax convertor, 3.42 gears, hooker headers.
Don't know how to post the tune.
Rick
Old Aug 9, 2013 | 05:32 PM
flywheel's Avatar
Dang, 130plus views an only one comment didn't think it would stump everyone....
Rick
Old Aug 16, 2013 | 07:51 PM
flywheel's Avatar
Just ended up being the tps . yea
Old Aug 22, 2013 | 06:58 AM
locrzn's Avatar
I had the same problem, worked on the final minimum idle vs rpm vs gear. I'm really close now and just have a few issues between short stops, say between stop signs. I'm getting close. Glad you got yours figured out. Its tough to tune a bigger cam like ours on the street.
