Intermittent electrical problem
Old Aug 11, 2013 | 12:09 PM
Buckndol's Avatar
Default Intermittent electrical problem
I have a problem I need help with. My car is a 1936 Olds Coupe. I installed a 6.2 with Magnuson TVS 1900 and 4L80E. The ECM is under the driver seat.
When I least expect it, or when I am on a narrow highway. the car will stumble a few times, then backfire a few times then go dead. Will not restart. If I open the hoods and let it set 10 to 15 minutes it will start as if nothing is wrong. Five miles later, on a narrower part of the road, it will repeat. I U
used a noid light and know there is no power to the injectors when this happens. I did not check the plug for fire, but the backfiring would indicate the fire to the coils is also interrupted. I replaced the ECM and it does the same thing. Engine temperature is normal and fuel pressure is constant. Something seems to be intermittently cutting power to the coils and injectors. Any ideas on this ????
Old Sep 12, 2013 | 03:11 PM
Buckndol's Avatar
A friend suggested it was the crank position sensor. That seems to have fixed it.
Old Sep 13, 2013 | 09:44 AM
codyvette's Avatar
This had me curious. Thanks for the update.
