cylinder 1 misfire
Old Sep 10, 2013 | 04:48 PM
85IROCZmaro's Avatar
Default cylinder 1 misfire
so i have a 99 camaro z28 with heads cam intake. got a tune back in april and now i have a cylinder 1 misfire i changed the plug/wire swapped coil packs and injectors and it still stays on cylinder 1 the compression is fine and i did a noid test on cylinder 1 and 3 and cylinder 1 seems very weak compared to cylinder 3 so im assuming the tune? any advice or other tests to do would be appreciated.
