Eliminating Fuel Tank Pressure Sensor
Old Sep 12, 2013 | 08:02 AM
RENE'S RAGE's Avatar
Default Eliminating Fuel Tank Pressure Sensor
Race car only.
Can I do away with the fuel tank pressure sensor?
What exactly is it's purpose ?
Old Sep 12, 2013 | 04:20 PM
fieroguru's Avatar
Yes, just turn off the DTC for it and remove the wires. Or do like I did and wire in the wideband to the 0-5V sensor wire.
Tank pressure is used as part of the evap system.
Old Sep 12, 2013 | 06:24 PM
How will the tank vent it's pressure if you remove the sensor?
Old Sep 13, 2013 | 07:45 AM
fieroguru's Avatar
I have a non-ecm controlled tank vent - 88 Fiero.
Old Sep 13, 2013 | 09:10 AM
I did some research and found the answer.
Just undo the evap line before the canister and
put a filter on it.
