Holley hp and dominator differences
Old Sep 18, 2013 | 08:29 PM
Twin turbo c5's Avatar
Default Holley hp and dominator differences
What is the differences between the holley hp and holley dominator from what I'm reading both have data logging. There's some fast turbo cars with the hp setup but should I just go with the dominator instead any better things about it I should know . Thanks
Old Sep 19, 2013 | 01:22 PM
cyipher's Avatar
Firmware
Both systems share the same firmware.
Hardware
The following differentiate these two ECU’s:
- Wide Band Oxygen Sensor Inputs
-HP – One input
-Dominator – Two inputs
- The Dominator can control certain Drive by Wire throttle body applications, the HP does not.
- The Dominator can control certain Electronic Transmissions (GM 4L60/5E and 4L80/5E), the HP does not.
- Inputs and Outputs
-HP
- 2 high side (+12v) PWM or switched outputs
-2 low side (ground) PWM or switched outputs
-4 Multi-inputs
-Dominator
-20 high side (+12v) PWM or switched outputs
-16 how side (ground) PWM or switched outputs
-6 speed inputs (magnetic or hall effect)
-30 0-5v sensor inputs
-13 Multi-inputs
- The Dominator has a “configuration input selection” pin that allows up to 4 calibrations to be selected with a key switch.
Wiring Harnesses
Both systems use the identical “main” wiring harnesses.
Old Sep 24, 2013 | 02:40 PM
Wicked69's Avatar
Do they work with low impedence injectors? Without a driver box?
Old Sep 24, 2013 | 06:04 PM
Black Reign's Avatar
yes they do
Old Sep 24, 2013 | 07:46 PM
samdogmx's Avatar
basicly the dominator has more room to grow down the road.
Tons more inputs & outputs.
ability to do 2 widebands
can do DBW throttle
can control electronic gm transmissions
Old Oct 5, 2013 | 07:08 PM
Does the holley hp work with factory coils???
Old Oct 5, 2013 | 11:03 PM
samdogmx's Avatar
yes it does
