Need Help Using Edit To Lock Converter On Dyno
Old May 3, 2004 | 09:14 PM
2xLS1's Avatar
Default Need Help Using Edit To Lock Converter On Dyno
Can anyone give me a quick rundown on what to change with edit to lock a converter at in 3rd at WOT for a dyno pull?
Old May 3, 2004 | 09:48 PM
ISPEEDWS6's Avatar
got to change your down shift speeds to less than 30mph is the trans/shiftspeed/tabs
Old May 3, 2004 | 10:01 PM
2xLS1's Avatar
I don't mean not downshifting to 2nd, I mean keeping the TCC locked when you go WOT. Do I only need to adjust the Performance MPH vs % TPS or do the Normal and Cruise tables need to be adjusted also?
Old May 4, 2004 | 06:19 AM
NoGo's Avatar
Set the TCC lock to 2 mph higher than the 3rd gear shift point for all TCC tables (exculding those not used.....ie 255 for all of the values). This will lock the TCC once the car shifts to third. Just make sure that you put the auto in nuetral once you get off the gas.
-Kevin
Old May 4, 2004 | 10:50 AM
samz28's Avatar
yeah kevin what happens if ya dont
Old May 4, 2004 | 12:08 PM
NoGo's Avatar
If you set the TC unlock values to something unreachable it will kill the car when the speed comes down. Its like haveing a manual in gear with the clutch out.
Old Nov 1, 2004 | 10:34 PM
WicketMike's Avatar
-Kevin
what if it still doesnt lock up?
