Necessary Mods to run LS1 ECM on a 5.3
Old Sep 27, 2013 | 04:10 PM
Bilster's Avatar
Default Necessary Mods to run LS1 ECM on a 5.3
I'm running a stand alone wiring harness and matching mail order-tuned ECM to run my 5.3. I have an older version of HP Tuners with 1998-2000 LS1 F-car credits. No other credits can be purchased for this HP Tuner package. I want to copy the tune on my current ECM and install it on a 1999 LS1 F-car ECM I have purchased. Is this possible? Will I have to change certain sensors...like the MAF , the oxygen sensors or??? Injectors flow very similiar between the LS1 and truck injectors so am I good there?
Old Sep 27, 2013 | 04:51 PM
boostit5.3's Avatar
are you sure its good for 98 thru 2000? i have an older hptuners serial cable and i only have unlimited 1998 f-cars and unlimited 2002 f-cars.... do you know what year/model the mail order tuned ecm came from?
Old Sep 27, 2013 | 04:55 PM
boostit5.3's Avatar
also if the mail order harness is pinned for a truck ecu im not 100% but the fbody ecu might be pinned totally different.
Old Sep 28, 2013 | 12:48 PM
Bilster's Avatar
You are correct boostit, unlimited 98, 99, 2002 F-car. You're harness discussion makes sense. If that's correct, then I need an F car harness to run my 5.3 with the F car ECU. Would I have to use F car sensors...particularly the MAF?
