1998 ls1 into 2002 z28
Old Oct 7, 2013 | 06:29 PM
shanex25's Avatar
Default 1998 ls1 into 2002 z28
Hey guys, I've got a 98 ls1 and 4l60e and looking into buying a 2002 z28 roller that was a 6 speed car. It also has its uncut wiring harness and PCM. I do have a 98 PCM and stand alone wiring harness that's already been cut for my ls1 swap car that I'm not using. I plan on putting the 98 motor and 4l60e into the 2002 car. What's the easiest thing to do? Use the 2002 t56 harness and modify it to work with the 98 ls1? What's involved in doing that? Or buy an uncut 98 harness and mod that harnes to work with the 2002 car and also use the 98 PCM. I've looked around and haven't found much of an answer yet. Need some advice. Thanks
