Computer pin help
Old Oct 9, 2013 | 06:43 PM
silverls1z28ofdeath's Avatar
Default Computer pin help
Alright I got a question for you ls1 computer savvy guys out there. So I have a carb swap in my ls1 (I know the devils work to guys like you lol), and I need a little help with getting my cooling fans to operate again since it doesn't see that my car is running since I run a msd box and and my crank and cam sensor don't go to the factory computer no longer.
So my question is how do I get my coolant fans operational again with out using a switch. I know that the factory ECM grounds the fans to turn them on. Any ideas on how to get my fans to come on again by using a temp sensor to still activate my fans?
Old Oct 9, 2013 | 08:40 PM
Pacer Racer's Avatar
Use the temp sensor from one of the old TPI camaros
Old Oct 12, 2013 | 01:57 PM
Ok gonna give a bump here along with another question. I know that pin 42 and pin 33 on my ECM when grounded turn on my high speed and low speed fans (I don't member which one which at the moment, I look at the PCM pinout again). My question is can I just ground those wires so that my fans will always run when I jut turn the car on, or will it make them run all the time even when the key isn't on? Any help would be appreciated
Old Oct 13, 2013 | 11:19 PM
Bump on up
Old Oct 14, 2013 | 06:43 AM
LS1MCSS's Avatar
If you ground them, the fans will run all the time. Just get an aftermarket controller and be done with it.
