ls1 th350 problems
Old Nov 9, 2013 | 12:44 AM
Ls1fury's Avatar
Default ls1 th350 problems
Car was an a4 went th350 with rmvb..now I can't tune car...took it to rpm motorsports in Valencia and had no luck....car runs good till about 5k and then it pulls injectors out of enrichment....could it be something with the th350? They told me that it could possibly be a bad crank sensor, going back in a week...
Any advice guys :/
Old Nov 9, 2013 | 07:27 AM
MontecarloDrag's Avatar
It may be triggering some Vss Fuel Cut
Post your tune to check
Old Nov 12, 2013 | 08:07 PM
cantfind2nd's Avatar
Do you have a speedo signal ? Mine acted like that when i didnt have anything hooked up. Now I pull it from the front wheel abs sensor.
Old Nov 12, 2013 | 08:33 PM
Ed Wright's Avatar
9-Second Club
What is "rvmp"? You guys use more strange abbreviations. smh
I also have never heard the term "pulls the injectors out of enrichment" before. Man, we sure operate in different circles. Are you trying to say it goes lean?
Are you logging your injector pulse width? If so, what is it dropping to?
Guess you have logged your fuel pressure when it does this? Fuel pressure sitting in the shop means very little.
Old Nov 12, 2013 | 11:47 PM
LSX Power Tuning's Avatar
The best way to tune that is to tune change the tune to a 6 speed and retune the car. Without seeing the tune its a crap shoot but it sounds like they missed a limiter somewhere. There is no telling what gear the pcm thinks its in so it may not be a normal limiter that its hitting. Years ago I used to just delete all the auto codes but ran into some weird issues I could never figure out. I then started tuning all (th350, th400, glides, etc) as a 6 speed and all the weird issues went away. You dont have to have a vss in order for it work, my race and several other ones I tune regularly all dont have a vss sine they all have race brakes with different hubs. A vss does make it a little easier to tune but not a necessity.
Old Nov 13, 2013 | 04:14 AM
Ed Wright's Avatar
9-Second Club
I agree. I always start with a manual Trans cal. Just shutting off auto Trans codes doesn't get it done. There is a bit in there that selects non-electronic auto trans. That won't get it either. If VSS is used it is very easy to change to 40 pulses & recalculate the VSS calibration for the speedo.
