decitions on Holley/ECU/Pro/???
Old May 11, 2014 | 03:19 PM
  #81
oscs's Avatar
Originally Posted by soundengineer
it hoenstly doesnt..... learning how to shift fast is better than needing control because you shift too slow... buying an auto solves all your issues and makes you faster.
I know how to shift my car. Please explain to me how NOT lifting your foot off of the gas is slower than standard shifting methods......
Old May 11, 2014 | 03:21 PM
  #82
oscs's Avatar
Actually don't waste your breath, thanks.
Old May 11, 2014 | 03:23 PM
  #83
soundengineer's Avatar
I just said you dont need a special deal to control rpm when you try to shift....
not lifting is always going to be faster than letting off the gas...
and I said if you want the ECU to limit RPM's you can use the 3step or a timing retard....
most people who want this feature, shift slow and dont want to bang their rev limiter because of their slow shifting....
learning how to shift fast makes it so you dont have to worry about it anyways.
Old May 11, 2014 | 03:28 PM
  #84
oscs's Avatar
I just said you dont need a special deal to control rpm when you try to shift.... not lifting is always going to be faster than letting off the gas... and I said if you want the ECU to limit RPM's you can use the 3step or a timing retard.... most people who want this feature, shift slow and dont want to bang their rev limiter because of their slow shifting.... learning how to shift fast makes it so you dont have to worry about it anyways.
"Only people who need an option to control no lift shifting are slow shifters" got it... Thanks.
Old May 13, 2014 | 11:55 PM
  #85
bmf5150's Avatar
My advice is to go with two wide bands, my car idled and ran way better when I added the second wide band to my dominator setup..
Old May 14, 2014 | 09:19 AM
  #86
oscs's Avatar
I went with the double wideband package
Old May 14, 2014 | 10:15 AM
  #87
ls1CANTU's Avatar
where did you place both wide band's at? on each bank before turbo?
Old May 14, 2014 | 11:15 AM
  #88
oscs's Avatar
8" post turbos
Old May 19, 2014 | 10:52 PM
  #89
10sec_rx7's Avatar
7 Second Club
Originally Posted by lm1clive
whats the Haltech like for Closedloop 02 WOT...
Works perfect on petrol, Ethanol, Methanol etc..
