BCM questions
Old Jan 6, 2014 | 04:08 PM
918_carb's Avatar
Default BCM questions
Ok. I have an 01 z28. Sold the motor, computer and harness. Bought a 6.0. Going carb with it. My question is, how do I get the bcm to work for my Windows and everything else it controls? Thanks
Old Jan 7, 2014 | 07:37 PM
BRUTL's Avatar
your windows actually dont use the BCM. Drivers windows goes through the express down module in the center behind the dash, the rest is just a basic power window circuit. As far as powering up the BCM, you need to find power and ground for the bcm, and I believe the engine harness is one of the three connectors to the BCM. If you give me till tomorrow, I can get you the pinouts for the BCM so you can run it standalone without the PCM.
Old Jan 12, 2014 | 04:41 PM
918_carb's Avatar
Thank you. I thought it was a separate module. Much appreciated
