Lm7 swap questions
Old Jan 13, 2014 | 08:39 PM
ls1guy1968's Avatar
Default Lm7 swap questions
i will be doing aan lm7 swap in the near future and have been doing alot of research on it. i will be going with a gto intake with injectors and rails and ported ls6 heads and ls6 cam or slightly larger my question is when i get my PCM flashed and vats goe and what not will i be able to start it with the mods on it or will i have to go straight to a tuner unknowing if it will run
thanks guys!
Old Jan 13, 2014 | 11:53 PM
LSX Power Tuning's Avatar
With the different injectors it will not run very well or at all if the pcm isnt set up for them.
Old Jan 14, 2014 | 10:30 AM
gagliano7's Avatar
Do a mail order tune so you can get it running with the correct data for startup. Then you can get it dyno tuned later.
Old Jan 14, 2014 | 04:16 PM
ls1guy1968's Avatar
What's a good place to send it in to?
Old Jan 14, 2014 | 06:23 PM
We are still running our sale, $150 plus $20 return shipping with a one day turn around time.
Old Jan 15, 2014 | 08:05 AM
gagliano7's Avatar
There you go^^^
