Doing 98 harness conversion, why no guides on removing evap, egr....?
Old Feb 15, 2014 | 05:57 PM
vetteguy112233's Avatar
Default Doing 98 harness conversion, why no guides on removing evap, egr....?
I'm fitting a 98 5.7 LS1 and harness into a 68 Camaro. I finally received my 12200411 99-02 PCM and am trying to repin everything, but nobody has a guide on what to remove if you don't need the emissions crap.
Here in Utah we can register vehicles 30+ years as vintage and they no longer need inspections or emissions.
I am following the "MRK Motorsports 98 conversion" guide:
http://www.mrk-motorsports.com/pdf/1...1999%20PCM.pdf
and it's having me swap over some evap stuff, but not others. It looks a lot like the "chips by al" guide, which clearly states at the top that the guide is meant for non emissions vehicles.
Is there a guide I'm missing for swapping this into an older car (68 Camaro) that shows all the wires and connectors that can be removed from the harness?
Old Feb 15, 2014 | 06:16 PM
Looks like I need to follow this guide:
http://lt1swap.com/99-02_vortec_pcm.htm
But what about wiring a 4L80E trans into the mix?
