Beginner Transplant
Any feedback would be appreciated.
Then I built the harness. That was nice because I could put Weatherpack connectors where I wanted them to make maint easier. And it was slightly cheaper than buying the ready built harness.
Tuning and getting everything to work the way I wanted it to was the challenge. The programming software is good, but not great. And I had to learn all the in's and out's of EFI tuning. The learning curve is steep.
But, that was for a 600+hp SBF.
For my current LS1 project, I have been told that the stock ECU and harness can handle pretty much anything you can throw at it. Although I was tempted to use another Megasquirt, I'm using the stock harness and ECU. I'll add some connectors here and there, but otherwise leave it stock. Once the car is assembled, I'll have it dyno tuned.
My current engine is fairly stock for now. Just a small cam and head change. But as my engine program progresses, I may change to a different ECU later one.
The one thing I really like at bout the MS3 is data logging. The ability to log all that data during a 20 minute race is very valuable. I would consider the Megasquirt3 just for that feature alone.
There are a handful of ECU's that LSx swappers look for, but you should be able to find any of the information that you need right here on this forum.
