HP Tuners help on trans
Old Feb 23, 2014 | 03:42 AM
gtfodave's Avatar
Default HP Tuners help on trans
Hello, My gto has a problem on the 2-3 shift where it does not shift at the limiter it bounces the limiter and then shifts
I pulled the tune off my 04 automatic GTO just to see if it was my trans slipping or is my tune was a little off and not a trans issue and noticed that the 2-3 shift was 86 mph. I quite dont see that happening
the car is a factory geared car on a 275/50/15 rear tire. would setting this to about 74mph be a smarter move to eliminate this issue?
Old Feb 23, 2014 | 05:52 AM
MUSTANGBRKR02's Avatar
You could try that or adjusting rpm also. PCM needs to see mph and rpm to shift. Your transmission could be showing its age too and starting to slip some.
Old Feb 23, 2014 | 06:02 AM
gtfodave's Avatar
the trans has maybe 2,000 miles on it since being built, hoping it isnt a dead trans yet.
so would I be setting my mph to be closer to my redline or just a mph where i would like it to shift?
Old Feb 23, 2014 | 10:13 AM
RedMilleniumZ28's Avatar
I had this problem with my camaro when tuning i raised my shift points. and started to get a limiter type feel going from 2-3. after some exploring i found that my fuel cut was too low. under hpt it is "engine; fuel; cutoff, DFCO"; "Fuel Cutoff RPM vs. Gear"
Old Feb 23, 2014 | 01:58 PM
Russ K's Avatar
The stock WOT 2-3 is 68 mph, and a 275/50/15 tire is .2" shorter than the OEM tire. At 86 mph, you will be hitting close to 7000 rpm. And the shift mph has to be at least 5 mph lower than the shift rpm.
Can you post your tune? What is your desired shift rpm?
Russ Kemp
Old Feb 25, 2014 | 02:29 AM
gtfodave's Avatar
thanks man that does sound like what i may be having, im gonna pull the tune tomorrow!
Old Feb 25, 2014 | 02:32 AM
gtfodave's Avatar
Russ Kemp
desired would be between70-78 if possible I am going to pull the tune tomorrow, thanks for your help
