HP TUNERS help with afr error pid and histogram
Old Mar 3, 2014 | 01:16 PM
pastvertical's Avatar
Default HP TUNERS help with afr error pid and histogram
hello, im trying to tune a 2008 z06. its a heads,cam car.
im having a problem with afr error. i made a new table to log files. i added the afr error to the pid. i loaded it to the hpt pro cable.
i logged the car for 12 mins ( all idle)
i got to retrieve the log, and it says unsupported parameters where i listed afr error.
what am i doing wrong?
Old Mar 3, 2014 | 08:28 PM
MustangPunk's Avatar
You need to have all the PID's being logged in the table(primary) display that's where it actually logs from for them to work in all the histos, charts, etc.. Make sure your user defined pids are correct, double check the function lines if used... and whatever pids are in the function lines need to be inserted into the table display to be logged also..
Old Mar 4, 2014 | 10:52 PM
COSPEED2's Avatar
LS1Tech Sponsor
If you need tuning help, we have options to help you on your way.
