Electrical question
Need some advice/assistance. I have a 00 ta that i have done a wire hide and also t56 swap, among other things. My issue is when you turn the ignition key to the "ON" position, the starter engages. My second issue is i have no display on my odo. Everything else, lights, horn, radio etc. work fine. Not sure if im getting spark to coils yet.
I did the wire mod pretty fool proof, used a numbered sticker on each wire. I also spliced the dark green and purple wire on the auto shifter sensor (the sensor that reads if the car is in park), they are together.
I've ran all my grounds back to the battery.
Will a bad ignition cylinder cause these issues?
Where would be a good place to start my diagnosis?
Thanks
I forgot to mention that i do not have any idiot lights now either. The only lights that light up in the cluster is the service engine soon and security. The security light comes on for a few seconds then goes off, it doesnt blink.. Also, i know i have power to my odo because when i cycle the key to the off position, the display will flash solid red for a fraction of a second
