Flooding
Old Mar 22, 2014 | 07:50 PM
has10390's Avatar
Default Flooding
Hey i have and ls1 that i purchased it floods bad. Computer has not been tuned it has a cam ls6 intake 36lb injectors. It will not clear up just smokes frome the fuel. Is this normal?
Old Mar 23, 2014 | 02:52 AM
subeone's Avatar
yes it is normal. Get a tune.
Old Mar 23, 2014 | 08:25 AM
MMWS6's Avatar
Don't drive this car until tuned. You are massively flooding cylinders and going to do major damage to your ride. Those 36lb injectors are actually 42lb injectors at 4 bar, your getting almost double the fuel the computer thinks its delivering. Once at a tuning shop, have the oil changed immediately before you even begin the tuning process
Old Mar 23, 2014 | 03:33 PM
subeone's Avatar
or they could be 36 lb rated @ at 4 bar from GM.
Old Mar 23, 2014 | 05:07 PM
MMWS6's Avatar
... if so that is a solid 25% increase in fuel delivery, and that is saying the PCM had 28lb injectors stock. If it's an older LS1 it will be an even greater increase. Still enough that is going to do damage if not corrected in short order.
Old Mar 23, 2014 | 11:33 PM
subeone's Avatar
fuel trims can pull about 25% fuel... either way i agree he needs his pcm calibrated.
