Computer change now engine light on
Old Mar 26, 2014 | 12:31 PM
chadschoon's Avatar
Default Computer change now engine light on
Ok, here is a quick run down. I have a buggy with a 05 LQ4 in it. It had Drive By Wire. I wanted Drive By Cable so I had to find a computer that I could change that to because mine couldnt change. I found one that would work out of a 05 express van. I had my tuner switch the harness and burn my tune into the ECU. I got it all back an hooked up but now I am throwing an engine light that both my upstream (only ones I have) O2 sensors are bad. I look at the sensors from the truck and van and they have different connectors. Could this be the issue? Running o2's from a truck but the computer may be getting a different reading because of the different types of connectors? My tuner said it doesnt matter because they use the same wiring. Any ideas on this? I just dont think my O2's both went bad at the same time with just this change.
