Configuring HP Tuner output enable/disable logic
Old Mar 29, 2014 | 08:57 PM
1slowbusa's Avatar
Default Configuring HP Tuner output enable/disable logic
Hi,
I know how to configure the output but as far as setting the trigger and disable trigger, this is where I have questions.
Say I wanted to use an and logic, I wanted to activate my nitrous solenoid greater than 3500 rpm and 100% throttle. How do I write that in the trigger string?
Same goes for the disable trigger stream but an or statement (disable when KR greater than 0 or wideband is greater than 12.5 AFR)
Also, what is the module output voltage? 12V. It is not like a dry contact where I can source my own 12v.
Thanks in advance
Old Mar 30, 2014 | 01:09 PM
1slowbusa's Avatar
Ok, so I found the Output info. Apparently it is a sinking ground and not a sourcing output.
Enhanced IO specifications
Four high impedance, buffered, filtered, 10 bit 0-5v analog to digital conversion channels that can connect to almost any device.
Input impedance greater than 4meg ohm.
A/D inputs can tolerate short term over voltage without damage.
One 5v output 200 milliamp max (for powering external sensors).
Employs short circuit protection
One ground reference tie point.
Two sink to ground 190 milliamp maximum each, continuous duty device drivers.
Control external devices by providing a ground when commanded on.
Driver circuits CANNOT tolerate an over 200 milliamp short. Do not exceed these limits or you will damage the outputs. If you are unsure of the device/circuit you are testing contact us at support@hptuners.com
Always use a 200 ma fuse in line with you connected device.
Blown output transistors will NOT be covered under warranty.
