M6 swap - not enough throttle hang while shifting.
Edit for some more car info: 98 TA 6.0 LQ4, stock heads/cam, ls6 intake, lt headers. Pretty much stock motor.
So Im guessing I need to adjust the throttle follower decay... beings that I need the throttle to hang when the clutch is in, Im assuming Ill need to adjust the P/N Decay Rate?
I also hate the stock 800 rpm idle speed - wants to crawl too fast in carparks - I drop it to 600 with no ill effects. However this requires changes to desired idle airflow, and requires more changes to throttle cracker and follower to increase the rev hang back up.
