codes after unplugging maf
Old Apr 27, 2014 | 09:05 AM
warriorpluto's Avatar
Default codes after unplugging maf
OK my car was down on a lot of power and I have been searching for the past few months and finally found the issue. It was my maf sensor. It threw no codes. I even cleaned it but it still made my car slow when plugged up and used a ton of fuel . 11 mpg. I unplugged it and the car is so much faster and runs better also gas mileage is a whole lot better than before. I wanted to ask, if the sensor is unplugged, should it only be showing the code for the maf sensor? I cleared the codes just to make sure and as soon as i crank it up I also get codes for the two front o2 sensors. If anyone had any experience it would be greatly appreciated .
Old Apr 27, 2014 | 09:53 AM
danieloneil01's Avatar
What's the codes you're getting for the O2 sensors? As to your question, no you should not get any codes other than the MAF codes.
Old May 6, 2014 | 01:48 PM
Yes I'm getting o2 sensor codes and other stuff when I unplug the maf sensor. I'll 're scan post the codes later today
