Starts bad
So it's a problem when running in Open Loop
there are no SES lights right? (can you scan to make sure there is definetly nothing... maybe codes that don't set a light)
MAF, TPS and IAT are all plugged in?
Engine Sensor Fuse isn't blown?
The car runs in open loop when you first start the car sice hte O2s aren't warmed up...
sensors it needs for this are MAF, TPS, MAP, IAT, ECT, and engine speed... so check the connections at these sensors
once it's running ok have you tried going WOT or have you not wanted to chance it?
