ABS/TC/BCM questions!!!
So in theory, i need a TC switch, a 4ch cars bcm, and have it flashed to my VIN or have my tune adjusted instead of living with no abs and having to look for axles and drill into my rear end.
Anyone have any expericence or lead me in the right direction? seems to easy to be possible.. and my old axles are toast...
Really not worth the effort, just pull the bulbs out of the gauge cluster and drive on
I don't think you can really go from 3 channel to 4 channel very easily though without tons of wiring. It all depends on whether or not GM uses the same wiring harness for 3 and 4 channel cars. I know they differ some but to what extent I'm not sure. Plus like mentioned above, you would need a 4 channel EBCM, route a brake line from the engine bay to the rear axle!, traction control computer (one under the dash), traction control module plus all the throttle cables. I have most of this stuff if you really want to give it a try though.
ABS and traction control are not at all tied to the PCM either in the sense you can tune it.
