New Jersey MAP kpa?
http://www.fastfieros.com/tech/map_s..._they_work.htm
http://injector-rehab.com/shop/mapsensor.html
http://www.useasydocs.com/details/map.htm
I'm not saying everyone needs to be an expert in tuning, I'm far from it, but if you are at this stage of modifying your car, that you need a 3-bar map sensor, you should have a good idea of what's going on and realize that the map sensor doesn't need to be calibrated at different elevations. It's job is to make adjustments based on those elevation (really it's air density) changes.
Currently my car is NA running a 3bar map. I have different values in the tune right now for map sensor linear and map sensor offset.
The settings are 283.01kpa map sensor linear and 10.33kpa map sensor offset.
These settings give me a MAP kpa reading of about 100kpa when running.
My car is a 02 transam with a 430lsx race block all setup for boost with a blower cam running a fast 102 and nw 102 tb. I have an sd tune on her now and I'm running NA currently.
This is why I'm asking because I am told when driving the MAP value should be at 100 for an NA car.
So is it correct for me to adjust to get that value and deviate from the manufacturer linear values or is that incorrect?
Did you even bother to read the links I gave you above?
OK, I will try again.....
At sea level with the key on, car off your map should read 100 KPA or 14.7 psi (which is approximatley one atmospheric pressure). Many things affect this reading, temp, DA, humidity, etc.... but generally with the key on car off, that's about what you should read. The manufacturers of the MAP sensor build and design there MAPs and then calibrate them (figure out what the linear and offset is) and provide those numbers for the tune so that when you are at sea level you should see 100KPA with the key on and car off (see the theme here).
Now when you start your car up, depending on what your cam is, you are going to pull some vaccuum (pressure less than 100KPA (14.7psi)) and you car should/will idle less 100KPA. For instance, the LS3 in my truck idles at around 55-60 KPA on most days (Comp cam 219/235 113 LSA). My 2014 Camaro SS with the factory cam idles at around 40-45KPA. Which makes sense, a smaller cam will generally pull more vaccuum.
On to the next part of the story, a NA engine at WOT as talked about above, you should pull virtually no vaccuum at all (100KPA). So if you are data logging, your MAP reading should be clsoe to 100KPA (14.7 psi or 1 atmospheric pressure).
OK, final part, forced induction. I have a TVS1900 Magnacharger, as my blower comes in, I start to build boost (boost equal any pressure above atmospheric(>100KPA)). So as my blower increases pressure, my MAP readings start going above 100KPA (hence the reason for needing a 3 bar map or one that will read up to 300KPA). In my case, my max reading is around 160KPA or approximately, 22PSI. If I subtract out the 14.7 (atmospheric pressure at sea level), 22-14.7 = 7.3. This tells me my blower/engine combo is making about 7lbs of boost....
I'm sure there are some guys on here that can explain this much more eloquently than I, but this is my shade tree mechanic version of how it works.
I ask a lot of questions my self, but I follow it up with researching. Actually I research first, then ask questions, and then do more research.
Working through some issues and because my car is NA I believe I'm having an issue with running a 3bar map.
I'm gonna drop it down to a 2bar GM sensor so I can get the right values in and see what happens.
I can't get the fuel right at the lower rpm range no matter what we do.
You know my dilemma I outlined it above can I use a fast 3bar map with no issues for an NA car?
That's all I got once I have that answer I'll move on
You have been very helpful and I truly appreciate it, just let me know when you can where you came across those settings because FAST cant even give them to me for whatever reason...
Thanks!
Thanks!
