PCM and programing guys please look in here
https://ls1tech.com/forums/showthrea...40#post1372240
need feedback if it's feasible to work with the pcm to adapt a 4 channel ABS rear signal to a 3 channel ABS car through its factory rearend plug.
Can an adapter wire be made to translate the axle pulses to ring gear pulses and accuratetly fool the pcm?
Please post ideas, suggestions or A SOLUTION to either thread - thanks!
The GM trucks only have 3 VSS's, 2 front and one rear. The rear VSS is in the back of the tranny somewhere. Anyway, a truck PCM is set up to work with three VSS's.
I'm not sure here, but maybe someone else knows if you could adapt a truck PCM for your application?
