Idle tuning help!
As far as the idle, if you follow the known way of calibrating your VE table, followed by the MAF table, both in open loop, using a wideband, you can resolve a large portion of your issues. Additionally, EOIT can help out with big cams at idle.
If you have to drill a hole in your throttle blade, you are not tuned correctly. Band-aid fix.
I said that I get it enough to run. Then I tune the rest of the car and then the idle last or close to last.
