My experience with Accel DFI
Old May 18, 2004 | 10:25 PM
Ryan K's Avatar
Pathological Modifier
Default My experience with Accel DFI
Alrighty then. So, I ordered a DFI setup from Joe Overton. First off Joe is a hell of a guy and offers a great deal on the DFI system. It had been sitting here in a box for about a month and a half waiting for the car to be ready for the install.
I chose a stand alone system and to remove the factory PCM. I have to tell you that this is a major undertaking. It means making a custom dash and removing a bunch of stuff. I guess you have to call this a race car mod, if you are going to pull the factory PCM. It requires a huge amount of wiring to get it all worked out. I also chose to COMPLETELY gut the factory wiring harness and start off fresh.
The DFI is nice, but the harness is utter crap. None of the harness connection points are in the right places. They try to make it pretty, but I personally think that it should come as a flying wire kit. That way you can make the harness to length for your application.
On that note, I'll talk about my major snag. Accel Tech support are a great bunch of guys. But this problem held me up for over two weeks. The harness for the ignition was incorrect, the CKP sensor connector was wired up wrong and was not reading the CKP sensor. We, Accel and I finally talked throught it and got it figured out but, Man what a PITA!
As of this writting, the car is up and running, but I still have to re-route the harness due to the troubleshooting efforts.
More to come with tuning!
Ryan K.
Old May 19, 2004 | 07:12 PM
Bink's Avatar
Ryan K- thanks for the post. Is this a speed density/ mafless setup??
"I personally think that it should come as a flying wire kit. " - I'm not sure what you mean?? Long length wires with connectors?
Keep us posted on your progress - please
joel
Old May 19, 2004 | 07:22 PM
Ryan K's Avatar
I think they should sell the harness as a kit. Basically you get the leads connected to the ECM and you make up the connectors for the sensors your self.
Ryan K.
Old May 19, 2004 | 10:22 PM
Bink's Avatar
Thanks.
joel
Old May 20, 2004 | 06:45 AM
GTP40's Avatar
A flying lead harness kit is being produced, and will be available very soon.
Old May 20, 2004 | 01:27 PM
WAHUSKER's Avatar
Thanks Ryan! Sounds more complicated than I care for...maybe HP Tuner is the way for me.
