crank position sensor
Old Jun 16, 2014 | 08:10 AM
george88gta's Avatar
Default crank position sensor
Not sure if this is the correct forum, but here goes. We replaced the LS1 with an LQ4 in my 02 Trans Am. I had the PCM reprogrammed ( I sent it out )for the new engine. It starts and runs well. I did not perform a crank position sensor relearn. Is this necessary? I have a Tech II.
Old Jun 16, 2014 | 07:58 PM
joecar's Avatar
If you do it, the PCM will be able to correctly detect misfires.
