Carb Swap using Factory PCM Question
Well I hooked everything up and primed the pump a few times and checked for leaks. It fired right up, idled good, and seemed to have really good throttle response.
It is still blowing my mind how it is actually running?? NO MAP, NO IAT, NO TPS. I was thinking the computer would do some funky stuff with timing maybe even shutting the car off. Well now Im worried about what timing will actually be doing especially 6k and up.
I have access to hp tuners to scan and fix anything needed. Can anyone give me some guidance on how I can lock the timing in at 36*? Where nothing changes.
