can u check codes with edit?
Old May 20, 2004 | 05:38 PM
98tata's Avatar
Default can u check codes with edit?
as it says can you check codes with edit. and how to do it
Old May 20, 2004 | 06:25 PM
horist's Avatar
nope, LS1 Edit only lets you modify the PCM... HP Tuners is the only PCM editor out there now with the abilityt o scan the car (read codes) as well as edit the PCM
