change timing for higher CR?
Old Jul 29, 2014 | 07:39 AM
jimmyjam's Avatar
Default change timing for higher CR?
I just had my block bored and rebuilt with new pistons, I calculate the compression went from ~10.9 to ~11.2:1. should I take a couple of points off of the timing table across the board just to be safe?
I noticed my tuner set the high and low octane tables the same, is this a bad idea? I should still be getting knock retard if there is knock, right?
Thanks
Old Jul 29, 2014 | 10:55 AM
watman02's Avatar
Thats not a huge jump in cr. I would wait and see if u have knock. As that will pull timing.
