Code P1153
Old May 21, 2004 | 06:39 PM
2000TransAm24's Avatar
Default Code P1153
When I did my header install my passenger side AIR pipe didn't come close to the air provision on the header, so I cut the metal air pipe and put some silicon on it and smashed it flat on a vice to seal it and bolted it on the header. So now I'm running with air on my drivers side header but not on my passenger side header. So my question is could this cause the code P1153 HO2S Insufficient Switching Bank 2 Sensor 1? Thanks
Old May 21, 2004 | 09:07 PM
Assassin's Avatar
yeah,
why didnt you just bolt it on and get a longer hose?
Old May 21, 2004 | 09:11 PM
billc5's Avatar
P1153 and 1133, is a very common code for headers as this means that the sensor is not hot enough, headers by design run colder, lots of people just turn this code off. there are sensors that will run hotter but Ive never used them.
but then agian I could be wrong
Old May 22, 2004 | 07:30 AM
I was tired and it was getting late, and I needed a quick fix.
