trouble finding tables
Old Aug 14, 2014 | 09:08 PM
Rick Speed's Avatar
Default trouble finding tables
I was sent these numbers from an injector company but I can only find the 0-80 section.the 128-640 are no where to be found
MAP (kPa) 0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80
MAP (PSI) 0 0.72519 1.45038 2.17557 2.90076 3.62595 4.35114 5.07633 5.80152 6.52671 7.2519 7.97709 8.70228 9.42747 10.15266 10.87785 11.60304
New Flows
Injector Flow (g/sec) 6.930 6.973 7.016 7.059 7.101 7.143 7.185 7.227 7.268 7.310 7.350 7.391 7.432 7.472 7.512 7.552 7.592
Injector Flow (LB/Hr) 55.001 55.343 55.684 56.023 56.359 56.694 57.026 57.357 57.686 58.013 58.338 58.661 58.983 59.302 59.620 59.937 60.251
MAP (kPa) 128 144 160 176 192 208 224 240 256 272 288 304 320 336 352 368 384 400 416 432 448 464 480 496 512 528 544 560 576 592 608 624 640
MAP (PSI) 18.564864 20.885472 23.20608 25.526688 27.847296 30.167904 32.488512 34.80912 37.129728 39.450336 41.770944 44.091552 46.41216 48.732768 51.053376 53.373984 55.694592 58.0152 60.335808 62.656416 64.977024 67.297632 69.61824 71.938848 74.259456 76.580064 78.900672 81.22128 83.541888 85.862496 88.183104 90.503712 92.82432
New Flows
Injector Flow (g/sec) 3.920 4.158 4.383 4.597 4.801 4.997 5.186 5.368 5.544 5.715 5.880 6.041 6.198 6.351 6.501 6.647 6.790 6.930 7.067 7.202 7.334 7.464 7.591 7.717 7.840 7.962 8.082 8.200 8.316 8.431 8.544 8.656 8.766
Injector Flow (LB/Hr) 31.113 33.000 34.785 36.483 38.106 39.662 41.159 42.603 44.001 45.355 46.670 47.948 49.194 50.409 51.595 52.755 53.889 55.001 56.090 57.158 58.207 59.238 60.250 61.246 62.226 63.191 64.141 65.078 66.001 66.911 67.809 68.696 69.571
MAP (kPa) 128 148 168 188 208 228 248 268 288 308 328 348 368 388 408 428 448 468 488 508 528 548 568 588 608 628 648 668 688 708 728 748 768
MAP (PSI) 18.564864 21.465624 24.366384 27.267144 30.167904 33.068664 35.969424 38.870184 41.770944 44.671704 47.572464 50.473224 53.373984 56.274744 59.175504 62.076264 64.977024 67.877784 70.778544 73.679304 76.580064 79.480824 82.381584 85.282344 88.183104 91.083864 93.984624 96.885384 99.786144 102.686904 105.587664 108.488424 111.389184
New Flows
Injector Flow (g/sec) 3.920 4.215 4.491 4.751 4.997 5.232 5.457 5.672 5.880 6.081 6.275 6.464 6.647 6.825 6.999 7.168 7.334 7.496 7.654 7.810 7.962 8.111 8.258 8.402 8.544 8.683 8.820 8.956 9.089 9.220 9.349 9.477 9.602
Injector Flow (LB/Hr) 31.113 33.456 35.644 37.707 39.662 41.525 43.308 45.020 46.670 48.263 49.805 51.301 52.755 54.169 55.548 56.893 58.207 59.492 60.750 61.983 63.191 64.377 65.541 66.685 67.809 68.916 70.004 71.076 72.133 73.174 74.200 75.212 76.211
Old Aug 14, 2014 | 09:36 PM
2xLS1's Avatar
Different PCMs and different operating systems have different tables.
Old Aug 14, 2014 | 11:06 PM
Rick Speed's Avatar
ok well I'm using HP tuners on a 98 Trans Am
