Battery won't stay charged
Thanks in advance
loose ground ? corrosion on b+ cable ? loose plug connection ? shorted excitor wire ? is power steering leaking on the connection ?
all of those can cause this issue. I've seen grounds become brittle and crack/break apart, I personally had an open excitor wire when my car wasn't charging and chassis ground are one of the most common items forgotten when everything is reinstalled.
