Increase line pressure in reverse?
Old Sep 20, 2014 | 08:30 AM
TDMKR496's Avatar
Default Increase line pressure in reverse?
Just installed Jakes D3 trans brake in my 4L80E and I do not have enough line pressure in reverse. Which table controls line pressure in reverse? It currently makes about 80 PSI in reverse and I'm guessing that is not enough. I am tuning with EFI live and have a COS5 411 PCM, but the tables should be the same in EFI or HP. Any thoughts?
Old Sep 20, 2014 | 10:21 AM
LSX Power Tuning's Avatar
What's your pressure like in the other gears? You can increase your overall line pressure by decreasing D3801 but that will raise it in every gear.
Old Sep 20, 2014 | 05:08 PM
TDMKR496's Avatar
Thanks Lorenz, I decreased the table 10% and it raised the pressure 25psi and now the trans works great! Thanks for your help.
