Adjusting Shift Points EFI Live
Old Sep 22, 2014 | 05:54 PM
TDMKR496's Avatar
Default Adjusting Shift Points EFI Live
I need to adjust the shift points on my 5.3/4L80E PSI harness/411 PCM COS5 EFI Live Mustang. I know that you have to adjust the RPM in one table, but dont you have to adjust the MPH as well? Do you have to meet the MPH that need needs to shift at? I'm not sure how that works, any suggestions are greatly appreciated!
Old Sep 22, 2014 | 06:52 PM
LSX Power Tuning's Avatar
WOT or part throttle shift points?
Old Sep 22, 2014 | 08:09 PM
TDMKR496's Avatar
WOT shifts, thanks Lorenz.
Old Sep 22, 2014 | 11:03 PM
You would adjust the RPM under Shift at RPM>Upshift>Parameters, tables D0940-D0952. The MPH is under Shift at VSS>Upshift>Parameters, tables D0910-D0922. It needs to see the MPH and the RPM in order to shift WOT. Its easier to lower the MPH down some so you know it will shift at the RPM you want.
