HP Tuners Config question, a real newbie
Thanks in advance for any help as I am really new to tuning.
Config file cannot be attached here?? I was hoping I could so everyone could see what I was talking about.
Configuring User Defined PIDs
The first few PIDs in the user defined list are internal and cannot be modified.
You cannot modify user defined PIDs when you are scanning or have a log file open for playback.
For a user defined PID to function properly, the Sensors and PIDs you reference in the function must be loaded into the table display. If your user defined PID always shows a value of 0, either you reference a Sensor or PID that is not loaded into the table display or your function syntax is invalid.
Why would this happen and how do I now adjust the .5 volt variance from the HP default to what my LC1 needed?
Thanks
Mike
