pcm help
Old Oct 19, 2014 | 09:30 PM
nastytxz/28's Avatar
Default pcm help
I rebuilt motor installed somehow the alternator batt wire got mixed up and bolted to grounds on frame by abs installed batt cable sparks so i took it off . My main problem is now thats (fixed all grounds have been checked relays all in working order ) i get no fuel pump prime at fuel relay get my constant 12v then key in run get 12v but no 2-3 sec 12v for prime other issue starter will not turn over im getting no voltage to purple wire have 12v out of big red wire at batt couldim leaning towards a fried pcm due to the 12v alt wire to ground but not sure as i know vats is working ohmed key and checked plug under column both match just need help im new to ls game car iss 99 z/28 also speedo is pegged out all interior dash lights work horn blinkers
Old Oct 20, 2014 | 10:51 AM
1320's Avatar
im confusedget
"then key i run get 12v" where is that 12 v measured at? The fuel pump relay?
Can you jump the fp relay and turn the pump on?
I dont think you have enough to determine its the pcm yet, but its an easy swap to test.
I would swap the pcm, cause I have some around. But I m not convinced that it isnt wiring /fuse related yet.
Can you scan the pcm with the key on? It sounds like the pcm ist getting power.
Old Oct 20, 2014 | 04:26 PM
All fuses and relays are good when i meter out the fp relay i get a 12v constant then when i turn key to run i still have 12v constant but i also have another 12v on second probe but no signal of 12v for 2 or 3 sec to prime but i tried jumping pump and nothing but i should still see the 2 to 3 sec prime then ill change pump im really conserned with the no cranking issue how would i check and what would i check to see if pcm is getting powered. Also i grounded the black/yellow wire bcm with no change
Old Oct 20, 2014 | 06:58 PM
Update starter batt fuse underhood has no voltage on it i pluged a obd cord in the port with no luck doing the same thing
