Why change ol eq ratio then pe table?
If in OL, the OLFA has the prevailing cell, and it is stoich, and the condition is WOT, then yes STFT trimming is performed (but of course stoich at WOT is not good).
Usually the Camaro/Firebird/Corvette calibrations had this disabled, but truck calibrations had this enabled and it would cause grief when trying to correct the VE table in OLSD.
If so, what will it use to determine STFT and does this apply in WOT conditions?
If in OL, and the OLFA has the prevailing cell, and it is stoich, then STFT trimming is performed, regardless of WOT.
There are various reasons for CL being prevented... if the operating conditions allow CL, then the mode will go to CL...
the key point from above was that when in CL, going to WOT does not cause the mode to go to OL... and PE enables but is not stoich, so previous learned LTFT's are modified (negative rounded up to zero) and added... (LTFT's are never added in OL).
