Speed Density
Old Nov 24, 2014 | 05:26 PM
nj02z's Avatar
Default Speed Density
When switching to speed density and using the VE afr error histogram, will the histogram read the error for pe enabled at wot or will it read the error from stoich at wot? So when I log at wot and I want 12.5 will it read error from that if pe is enable? Thanks.
Old Nov 24, 2014 | 08:03 PM
redtan's Avatar
I believe it will read based on commanded AFR in the PE table, so if you're commanding 12.5 at a certain rpm then it will show a % error from that.
