Can fuel tank size be tuned?
Can the fuel tank size be changed in the tune? I'm getting ready to do a 5.3 swap in to an '89 K5 here in CA and will have to swap over all of the smog and evap stuff to pass the smog ref inspection. One thing that I've been told may be a problem is the fuel tank pressure sensor may throw CEL's if it's used in a different sized tank since it would pressurize faster or slower than what the computer thinks it should. Is there a way to change the fuel tank size in the tune to prevent this? I've been searching around for a few days but most people just remove all of this stuff and I haven't been able to find a clear answer yet and was hoping the tuning experts here might know..
All of the components are coming from a donor 2000 Yukon XL and the PCM is an 0411 from a 2002 Silverado that didn't have any of the EGR or Air stuff that my donor does. The Silverado had a 26 gallon tank and the K5 has a 31 gallon tank and I will be adapting the newer sending unit to the older tank to keep all of the required hoses and FPS in place. What do you guys think?
Thanks
